atvforumet.no - atv - firehjuling - quad • Se emne - Polaris service koder
Innlegg MaxMekker » 31 Des 2008, 12:39
21 - Loss of Synchronization
22 - TPS Circuit: Open or Short to Ground
22 - TPS Circuit: Shot to Battery
23 - RAM Error: Defective ECU
25 - Transmission Input - Invalid Gear
26 - Vehicle Speed Sensor - Implausible
41 - Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 - Air Temp Sensor: Short Circuit to Ground
42 - Engine Temperature Sensor Circuit: Open or Short to Battery
42 - Engine Temperature Sensor Circuit: Short to Ground
45 - Barometric Pressure Sensor: Circuit Low Input
46 - Barometric Pressure Sensor: Circuit High Input
51 - Injector 1: Open Load
51 - Injector 1: Short Circuit to Ground
51 - Injector 1: Short Circuit to Battery
52 - Injector 2: Open Load
52 - Injector 2: Short Circuit to Ground
52 - Injector 2: Short Circuit to Battery
54 - Engine Temperature Lamp: Open Load
54 - Engine Temperature Lamp: Short Circuit to Battery
54 - Engine Temperature Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Open Load
55 - Diagnostic Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Short Circuit to Battery
56 - Pump Relay: Open Load
56 - Pump Relay: Short Circuit to Ground
56 - Pump Relay: Short Circuit to Battery
58 - Cooling Fan: Open Load
58 - Cooling Fan: Short Circuit to Ground
58 - Cooling Fan: Short Circuit to Battery
61 - End of Diagnostic Check
Runar Holm
MaxMekker
Tusenkunstner
