[phpBB Debug] PHP Warning: in file /includes/functions_content.php on line 664: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_content.php on line 664: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4203: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3418) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4205: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3418) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4206: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3418) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4207: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3418) atvforumet.no - atv - firehjuling - quad • Se emne - Frontplate
Norsk forum for firehjuling atv quad - en avdeling i 4x4norway.no
Letteste måten er å skjære ut den du har... Får kjøpt og, men husker ikke delenr. Hvis du har hurtigfeste foran er det derimot vanskelig å få bruk ei slik plate!
Spørs om jeg har mista plata da, mener at det var en plate rundt da jeg henta den. Har fastmontert vinsj både foan og bak, Warn RT25 men fjernstyring på begge.
Orginal platen fungerer som et "Dummy " panel når den er levert uten vinsj. Derfor lages det bare hull for fastmontert warn vinsj . Du har nok mistet den da
