hei er det noen som har elektrisk varme vest/jakke.
alla noe slikt
Tour Master Synergy™ apparel is designed to operate from a vehicle’s standard 12-volt electrical system to provide unmatched levels of warmth and comfort. With Synergy™ apparel, wearers can be warm without the bulk and discomfort typically caused by excessive layers of clothing. By providing increased warmth and mobility in cold temperatures, Synergy™ apparel helps reduce fatigue while increasing safety and enjoyment.
Each Synergy™ garment is heated by a series of durable carbon fiber heating elements, which generate safe, electronically controlled infrared heat. In addition to safe and even heating, carbon fiber elements are lightweight, flexible and safe to operate in wet conditions. It is carbon fiber’s light weight and flexibility that allows Synergy™ garments to fit comfortably under protective riding apparel.
trenger feedback
