atvforumet.no - atv - firehjuling - quad • Se emne - baklys/bremselys
baklys/bremselys
baklys/bremselys
Innlegg erik » 31 Des 2007, 18:02
Noen can-amere som vei hvor du henter + bremselysstrøm på en 400 xt
baklampa er - styrt(jord er +) sikkert ett gammelt imperie fenomen fra canada
må jeg kobble ett reele
Må ha styrestrøm til henger bremsene
sikkert mange som har hatt dette problemet ved tilhengerkontakt montering
ØNSKER ALLE PÅ FORUMET GODT NYTT ATV ÅR SKÅL!
erik
Bosted: Drammen
Innlegg erik » 01 Jan 2008, 19:53
erik
Bosted: Drammen
Innlegg okelbo » 02 Jan 2008, 17:10
Fant noe på nettet om dette for en stund siden, se om du kan bruke noe av dette.
If you are trying to hool up the led lights that come in most quad boxes, you will need a relay. I made it work on mine. You can wire the park light normal, but the brake light is different. The brake light wire has 12volts on it and when you hit the brake, the voltage goes away.
A typical horn relay will do the trick. Basically you hook it up that the 12volts on the brake light wire will energize the relay. As soon as you hit the brake, the power on that wire goes away, de-energizing the relay, which will give your brake wire for your LED power to light up. As soon as you release the brak and re-energize the relay with the 12 volts on the brake wire, the led brake lights will shut off.
When your quad is on, your park light is on, so the relay is energized. When your quad is off, your park lights go out, after the timer, and your rlay will no longer have power either, so no worries about your battery going dead.
Yamaha Wolverine 700
Yamaha Wolverine X2
http://www.arendal-atv.com
okelbo
Renovasjons sjef
Registrert: 02 Mar 2007, 22:16
Bosted: Vegårshei
Innlegg erik » 03 Jan 2008, 18:49
Nå er problemet løst brukte bare et lysreele og lot - kablen bremselys (den som kommer fra baklykta) gå til - styring reele så hvar det iorden Kjekt og vite ved kobbling hengerkontakt can-am :grin:
Brukte + styrstrøm fra vanlig baklys
erik
Bosted: Drammen
Brukere som leser i dette forumet: Majestic-12 [Bot] og 5 gjester
